C Chelsea64 Vu+ Newbie Feb 16, 2014 #1 In OpenPli I can set that the timeshift will start automatically either direct or after a few seconds. How can I do this in Back Hole 2.0.9 I have and Vu+ Duo2
angelofsky1980 BlackHole Driver Specialist Feb 17, 2014 #2 Chelsea64 said: In OpenPli I can set that the timeshift will start automatically either direct or after a few seconds. How can I do this in Back Hole 2.0.9 I have and Vu+ Duo2 Click to expand... I think you should use a plugin called Permanent Timeshift. Take a look in the plugin feed.
A amdsquad Vu+ Newbie Mar 11, 2014 #3 Is there any chance for the time shift to start sooner than after 5s ?
