Autotimer: filtering by bouquet doesn’t work by GUI (and other issues)
AlexWilMac
Moderator
As in the subject, when I want to set an autotimer filtering matches by Bouquets, it seems impossible using the GUI. So I always have to prepare it by OWIF.
I choose to enable the filter, toggle from “Channel” to Bouquet, it makes me choose the desired bout, I save pressing green… but if I verify it was correctly created I always find it chooses “Channels” instead of Boquets.
Is it me to do it wrong?
The second issue is that, if I create an autotimer using the filter Bouquets, in the GUI it shows the “All channels” parameter in its description. Instead, if I add channels one by one, it shows them correctly.
I attach my Autotimer list where there are ONLY "All channels" indicators, but they are not set this way (all are restricted to a specific bouquet).
