avermedia A867 - sky key
moRpH3u5
I have sky key (SKY ITALY) and am using avermedia A867. I have used this driver around 3 months ago and was able to scan channels. Now I used Blackhole 1.4.4E (which was tested and worked 100% with manual scan) and 1.6.1 and seems that both images are not working when trying to scan even manually.
Your help would be appriciated
Thanks
Thanks
It's very strange.
My principal device USB DVB-T is the A867 and works great.
I suggest to move to front USB port and make another test.
it's funny how it is not even scanning a single channel. so you can confirm since you are driver coder that a867 works 100% with Sky key?
Do you have correctly setted your Terexstrial Provider into Tuner Setup?
Try to verify it.
