avermedia hybrid +volar a828
baw
hello! i have this dvb-t avermedia hybrid +volar a828...there is some possibilities to use it with black hole 1.7.8... the driver i have it from avermedia site the file is this AVERMEDIA-Linux-x86-A828-0.28-beta.sh can i install it manually?
Thank you very much!
A driver exists... I will try to implement it.
  • Like
Reactions: baw
but there is a way to mannually install this driver for a828?
Drivers for A828 exists only in source code form and browsing the Avermedia package issued by the manufacturer, I doubt that is not yet portable to Mipsel (our boxes) arch .... Some tests follows ...
  • Like
Reactions: baw
You can not patch A828 drivers?
They come from?
No se pueden parchear los drivers para A828?
Han salido?
It's not a patch problem. Avermedia deliver driver for x86/x64 arch using some binary data and they are avaiable only for PCs.
Our Vu+ boxes are MIPSel arch ... to support your stick it's needed a new driver written from scratch that is out of my knowledge at the moment
