Background picture
komodo
Hi,
i can't find any info i the forum, so i have one question.
When i stop playing movie or some recordings, then last screen from the movie is at background till next reboot.
Is this normal behaviour or it's a bug ?
And if, how can i set some static picture, or it depends on skin ?
Many thanks.
I have VU+ Solo2 for few days, and with BH image is great, so good work :-)
Martin
Hi,
Many thanks.
I have VU+ Solo2 for few days, and with BH image is great, so good work :)
Martin
It's normal.
It's normal.
Thanks, but is there any chance to change this ? Maybe set some default image after player exit ?
Is there any technical documentation for this ?
I know that is linux, but there is no player process and everything is processed via enigma2 binary so i am courious how it works.
I don't know how Enigma2 works but you can try to setup ZappingMode plugin and try :)
This plugin can configure the zapping mode switching from hold last frame and black screen ... and I hope can be useful for your purposes :)
Thanks, i have installed this plugin, but there is only Mute and Hold option, but nothing changed if i switch from one to another :-)
P.S.
There is so many plugins, is there any description on the web ?
