Output di dmesg
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0201 128MB @00000000
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0xFF for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0xFF for chip on CS
nand_read_bbt: Bad block at 0x02720000
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007600000 : "rootfs"
0x000007600000-0x000007a00000 : "kernel"
0x000007a00000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
Cosa sta a significare?mi devo preoccupare?
