NO NEED TO BE SADE AND DO NOT THROW AWAY YOUR STB OK, FIRST WELL YOUR STB IS ON BOOTING AND THE SPINNER IS NOT ALWAYS ON SAY 4OR 5 TURNS SIMPLY CONNECT YOUR PC TO STB BY "ANY FTP PROGRAM" AND GO TO USR\SHR\ENIGMA2\ AND DELETE THE BAS SUB-DIRECTORY IN THERE AND YOUR STB WELL LOAD AS NORMALI am sorry but, not work for me, again on my uno
do not know Which receiver u are test this skin, but to me, my receiver does not start
i got it mixed up with the new file stupid me this is the new skin file
you are write but you know when you are programing skins sometimes you get mixed up with the skin.xml file and you have to modify that , but thanks for the advice but i need you to delete the other files and threads to ovoid any wrong doing by any member and leave the only last uploaded file "usr.tgz"Please make sure that the skins U post here are tested, plus U have to say on what STB!
أخي العزيز ارجو إختبار الغلاف قبل وضعه هنا في المنتدى وشكرا
################### Army_PureHD-Transparency-HD_VU_BH1.7.6.x_v.1.0_BH mod by fhroma ####################
QUESTA SKIN E' PROTETTA DA COPYRIGHT E PUO' ESSERE USATA SOLO PER
LE IMMAGINI BLACK HOLE. IL CODICE DELLA SKIN PUO' ESSERE MODIFICATO
SOLO PER USO PERSONALE MA SIA IL CODICE E SIA LA GRAFICA DI QUESTA
SKIN NON POSSONO ESSERE USATI PER FARE SKIN DIVERSE O PER ADATTARE
QUESTA STESSA SKIN A IMMAGINI DIFFERENTI DALLA BLACK HOLE.
THIS SKIN IS COPYRIGHT PROTECTED AND IS FOR BLACK HOLE IMAGES ONLY.
YOU CAN MODIFY THIS SKIN ONLY FOR PERSONAL USE BUT YOU CANNOT USE THIS
SKIN CODE AND GRAPHICS TO MAKE A NEW SKIN OR TO ADAPT THIS SKIN FOR
DIFFERENT IMAGES.
black hole version: 1.7.6
skin author: Army
