BBC iPlayer
skybandit
Is it possible to get BBC iPlayer working under BlackHole?
I found a package and installed it but BlackHole always crashes when I try it.
I have the same question. Is it possible to watch BBC iplayer with a Vu+ Uno in the UK.
If so, can anyone explain how?
Thank you
Thanks chev
Earlier on today (before I saw your reply), I managed to telnet the ondemand plugin. It seems to work ok but I don't find it very user friendly, especially as it seems larger than the screen on my tv.
@itenary
"...I don't find it very user friendly, especially as it seems larger than the screen on my tv..."
I can't help I'm not living on your island.
Thanks chev
Have you tried changing your screen position and size using uipositioner plugin?
Before I try using uipositioner, I'd like to make it clear that live tv fits the screen perfectly. It is only "ondemand" that appears slightly bigger than the tv screen.
Its worth a try... I thought my TV screen was bang on but was missing some of the borders as was to large... Just a suggestion it may not help... Been a while since I've used/installed on demand so can't remember the layout I'm afraid
