Behaviour after finishing timer recording or powertimers
AlexWilMac
Moderator
There is a strange behaviour of timers.
Sometimes, even if the TV is on, it shows a message which says that a timer finished its recording and now it's going in deep standby.
Not only that: the default answer is YES. So, if I'm not there to change the default answer, it'd do so.
I believed there was an option to choice the behaviour of timers and also of powertimers and, above all, the default answer but I don't find it any longer. Is there any somewhere?
In Main Menu, go into <TIMERS> and select <Autotimers>.
Press <MENU> and adjust <Edit new timer defaults>,<After event> field set it to standard.
It was and it is already set this way.
Anyway, it hasn't occured again, lately.
What is the difference between STANDARD and AUTO in this menu?
