best french addon..[Vstream] streaming in XBMC
tigrousad
The plugin is developed by a Lord Venom from xStream Murphy module.
To sum up, Vstream gives you access to various sources through which you directly from XBMC to access streaming content such as TV channels, reports, documentaries, series and movies.
tutorial:
thnx
Just change the player in addon setting - use Shiro workaround to Map context menu key
IT works great !
Envoyé de mon iPhone en utilisant Tapatalk
