Best image for Solo2
komodo
Hi,
wasn't here for a while.
Can someone recommend best image for solo2 ? Las time i'v tried BH 3.0.1 but it was not so good as my old 2.1.4.
But i want some new image, because my old is not playing some new movies, or there is no sound.
So is 3.0.3 better and with good performance ?
Or is there some other, better image ?
Thanks
Martin
You could try Open Black Hole 0.6 but performance is not the question.
Some images just support certain aspects differently.
But whot is your preferences ? From image BH 2.1.4 was alot fixes and imporved made by Bh and VU+ .
I think Bh 3.0.3 is good.
Try too OBH 0.6 if you can.
Thanks. what is difrerence between BH and OpenBH images ?
And i want to use hdglass16 skin, will it be compatible ?
I believe that there was lot of improvements, but i have lot of movies that i can't play. So i think i need new image with new codecs support.
And there are many movies whith no subtitles, and i don't know why.
