Best image for Vu+ Duo without crashing
Midi
Hi there,
I have a Vu+ Duo and the latest blackhole images crashed and Vu+ won't wake up from sleeping mode without need to turn it off from main power. Could any one suggest what best image and light to avoid crashing and freezing. I only use the vu+ duo to watch free to air channels and no complicated use at the moment. Simple and light image will do.
I still need an image that is flexible to use and amend. I am used to Blackhole image and know how to add bh tools to it. I did say at the moment I am only watching free to air channels but that only for the moment. I had an old blackhole image that was light and has no issue but can not remember or find where I can download it. the last 2 bh version did not work on my vu+ duo as they keept crashing.
You could look in Black Hole Duo images, and locate the image you used to use, it goes on for 34 pages:
http://www.vuplus-community.net/board/forums/vu-duo-black-hole-images.28/page-34
You can still do quite a lot, with the original images.
You might also want to read a few threads, in the VU+ Duo section, regarding the latest Black Hole images, as I think others have experienced problems, with earlier VU*+ receivers, like the Solo and Duo.
I did find this thread, but I'm sure there are others:
http://www.vuplus-community.net/board/threads/howto-extend-flash-in-bh-images.8187/
Hi bogdanm,
I was having similar problems with my Duo, installed 2.1.5 as you suggested and so far so good.
Thank you.
I'm having the same problem with latest image, Vu won't wake up, need to use the switch to turn it on and off.
I don't really use bh.
If you want an image that doesn't crash and do what you need out of the box, go for OPENVIX, this is the best image
