Best supported enigma 2 boxes in 2023
Maen84
Hello
Iam thinking to buy Vu dou 4k se.
1.Is this agood step now?
2.Is there better boxes with strong support and good hardwere because I heard that vu support decreasing rapidly?
I did a similar research last year, but it didn't last long. I found a Solo2 to replace my ageing Duo. I only discovered that I couldn't find any boxes (apart from Vu+) that would take an internal HDD. Don't know if that's a new trend or the actual standard now.
A lot of newer receivers, from VU+, have a HDD caddy, so that you can quickly slide the HDD in, and out, for replacement.
Some cheaper 4K STB (Octagon , Zgemma...) , have a an SD card slot so you can buy SD card a register on it.
You can also resister on externa usb SDD our HDD.
