I would recommend using LAN plugs instead of wireless, depending on how much you want to spend you can get something from 14 to 500mbs, I use the 200mb version to stream video to my PC from VU+ and works perfectly. I tried Vonets wireless ethernet bridge on a friends dreambox but he ended up switching to a long ethernet cable as the connection was unreliable.
