Request BH 1.7.8 not booting! Stays on Starting
XabiX
Hello,
I did an upgrade of my BH without initially upgrade the FGPA as required. Now the box doesn't even boot and it stays on Starting step.
I tried re-flashing the old BH image in order to get back to the same level but couldn't boot either.
Anyway I can upgrade the FGPA without the box booting?
thanks
XabiX
Hello,
thanks
XabiX
Can U connect to the STB with DCC program?
I did try to ping and connect to the fixed IP address but I couldn't. (no replies to icmp).
I will still give it a try with your proposed program.
I did try to re flash the old BH1.7.6 image that I had but with no success. then I try re flashing the 7.0 image from Vu+ directly but the same.
I hope the box is not broken :-((
I just tried and the box doesn't get it's IP address so couldn't use the DCC program mentioned above.
any other idea?
MERCI
FYI is what I get when I boot:
BCM74130011
012
K1
K2
K3
K4
K5
Shmoo Version=3.8
DDR Freq=0x0000018C
%00000001%
RC1=00000006
WC1=FFFFFFEB
RC2=00000017
WC2=0000003F
RC3=0000000E
WC3=FFFFFFEB
RC4=0000000E
WC4=0000003F
NWC=00000015
RC5=00000006
WC5=00000015
RC6=00000017
WC6=00000015
NRC=0000000E
RW=00000012
WW=00000055
G=00000000 R=0000000E W=00000015
BL=00000000
RC1=00000002
RC2=00000017
BL=00000001
RC1=00000004
RC2=00000018
BL=00000002
RC1=00000003
RC2=00000011
BL=00000003
RC1=00000002
RC2=00000014
BL=00000004
RC1=00000007
RC2=00000019
BL=00000005
RC1=00000007
RC2=00000019
BL=00000006
RC1=00000001
RC2=00000015
BL=00000007
RC1=00000003
RC2=00000013
3
COPY CODE
A567
BCM97413B1 CFE v2.26, CFE core v2.12, Endian Mode: Little
Build Date: Thu Jun 16 09:50:22 2011 (doliyu@doliyu_note)
Copyright (C) Broadcom Corporation.
writing vfd
New NAND flash at 18000000 offset 00000000 size 116736KB
New NAND flash at 18000000 offset 07200000 size 4096KB
New NAND flash at 18000000 offset 07600000 size 4096KB
New NAND flash at 18000000 offset 07A00000 size 2048KB
New NAND flash at 18000000 offset 07C00000 size 1024KB
New NAND flash at 18000000 offset 07D00000 size 512KB
New NAND flash at 18000000 offset 07D80000 size 512KB
New NAND flash at 18000000 offset 07E00000 size 1024KB
New NAND flash at 18000000 offset 07F00000 size 1024KB
DDR Freq: 396MHz
CPU speed: 405MHz
Memory Config: 64-bit UMA
Device Tech: 1Gb
Total memory: 512MB
Boot Device: NAND
Total flash: 128MB
Initializing USB.
Initialize First USB Controller
USB OHCI start : Power Switching Mode Changed from 2000902 to 2000b02
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
Try to Initialize Second USB Controller
CFE initialized.
checking usb
ACK :
writing vfd
Starting splash screen.
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:mem=48M mem=256M@0x20000000 rootfstype=jffs2 root=/dev/mtdblock0 rw
Loading: 0x80001000/7270688 0x806f0120/124336 Entry address is 0x80577fb0
TP1 Entry Address at 0x80000ffc = 80577fb0
Starting program at 0x80577fb0
**Exception 32: EPC=80577FB0, Cause=00008028, VAddr=00000000
RA=8700C78C, PRID=0002A044
0 ($00) = 00000000 AT ($01) = A0000000
v0 ($02) = 00010000 v1 ($03) = 00000040
a0 ($04) = 870561C0 a1 ($05) = 00000000
a2 ($06) = 8700C800 a3 ($07) = 43464531
t0 ($08) = 80577FB0 t1 ($09) = 8000FFC0
t2 ($10) = FFFFFFC0 t3 ($11) = 87076B08
t4 ($12) = 00000001 t5 ($13) = 87080BB9
t6 ($14) = 8700CE68 t7 ($15) = 3EA95587
s0 ($16) = 8700C78C s1 ($17) = 87010000
s2 ($18) = 00000000 s3 ($19) = 8704E7A8
s4 ($20) = 87150578 s5 ($21) = 87076EE8
s6 ($22) = 87150520 s7 ($23) = 87017B08
t8 ($24) = 000000FE t9 ($25) = 87076B2C
k0 ($26) = 87078FA0 k1 ($27) = 00000000
gp ($28) = 870561C0 sp ($29) = 871503D8
fp ($30) = 87033280 ra ($31) = 8700C78C
*** Waiting for system reset ***
I tried flashing with the 5.11 nfi original image with vu util 2.01 but I get:
1/Extract image
2/ Enter in CFE mode
3/ IP is set in the machine
4/ Upgrade the kernel image on the machine
5/ fail to upgrade your machine (step 4 err-code -21)
arg :-(
BCM74130011
012
K1
K2
K3
K4
K5
Shmoo Version=3.8
DDR Freq=0x0000018C
%00000001%
RC1=00000006
WC1=FFFFFFEB
RC2=00000017
WC2=0000003F
RC3=0000000E
WC3=FFFFFFEB
RC4=0000000E
WC4=0000003F
NWC=00000015
RC5=00000006
WC5=00000015
RC6=00000017
WC6=00000015
NRC=0000000E
RW=00000012
WW=00000055
BL=00000000
RC1=00000002
RC2=00000017
BL=00000001
RC1=00000004
RC2=00000018
BL=00000002
RC1=00000003
RC2=00000011
BL=00000003
RC1=00000002
RC2=00000014
BL=00000004
RC1=00000007
RC2=00000019
BL=00000005
RC1=00000007
RC2=00000019
BL=00000006
RC1=00000001
RC2=00000015
BL=00000007
RC1=00000003
RC2=00000013
3
COPY CODE
A567
writing vfd
DDR Freq: 396MHz
CPU speed: 405MHz
Device Tech: 1Gb
Total memory: 512MB
Boot Device: NAND
Total flash: 128MB
Initializing USB.
CFE initialized.
checking usb
ACK :
writing vfd
Try to flash an image taken from http://code.vuplus.com and report here a new serial output
Sent from my iPad using Tapatalk
Hi,
I have download the vuplus-image-vuuno-20121022182538.nfi image from http://code.vuplus.com and vu util 2.01 tells the same:
1/Extract image
5/ fail to upgrade your machine (step 4 err-code -21)​
If I connect back the serial to putty I see the same:
BCM74130011
012
K1
K2
K3
K4
K5
Shmoo Version=3.8
DDR Freq=0x0000018C
%00000001%
RC1=00000006
WC1=FFFFFFEA
RC2=00000017
WC2=00000022
RC3=0000000E
WC3=FFFFFFEA
RC4=0000000E
WC4=0000003F
NWC=00000014
RC5=00000006
WC5=00000014
RC6=00000016
WC6=00000014
NRC=0000000E
RW=00000011
WW=00000056
G=00000000 R=0000000E W=00000014
BL=00000000
RC1=00000002
RC2=00000016
BL=00000001
RC1=00000004
RC2=00000018
BL=00000002
RC1=00000002
RC2=00000011
BL=00000003
RC1=00000002
RC2=00000014
BL=00000004
RC1=00000006
RC2=00000019
BL=00000005
RC1=00000007
RC2=00000019
BL=00000006
RC1=00000001
RC2=00000015
BL=00000007
RC1=00000003
RC2=00000014
3
COPY CODE
A567
writing vfd
DDR Freq: 396MHz
CPU speed: 405MHz
Device Tech: 1Gb
Total memory: 512MB
Boot Device: NAND
Total flash: 128MB
Initializing USB.
CFE initialized.
checking usb
ACK :
FrontPanel Key : d1, 80
writing vfd
t2 ($10) = FFFFFFC0 t3 ($11) = 87076AC8
t4 ($12) = 00000001 t5 ($13) = 87080B79
s4 ($20) = 87150578 s5 ($21) = 87076EA8
t8 ($24) = 000000FE t9 ($25) = 87076AEC
k0 ($26) = 87078F60 k1 ($27) = 00000000
Strange because before I remember to be able to reflash. Last I tried was the vu official image 7.0 in USB if I am not mistaken.
