Request BH 2.0.4 EPG
verbal_666
Hey guys.
I set up EPG sync with internal epg management at 04:00 at morning.
It's ok, but after sync is done, STB doesn't go standby but stays on epg channel.
Is there a way to make it standby after sync, without other cron scripts?​
Hi, can you explaine me how set up the automatic epg with BH 2.0.4. Today I bought the duo2 so next week they send me the new vu2.
get your box first, have a play a bit then ask if you'll find something unclear. Menu is user friendly and you should catch it up very quickly
