Thanks for the update. The only problem I experienced was that my menu language was changed to Spanish. It's fortunate that most menu points are called the same so it wasn't too difficult to find "Language" and change back to English.
I thought that the AGC fix for Solo2 would correct the problem some of us have had getting a lock on high band frequencies in good weather but this is not the case. The frequency still has to be upped by 1 or 2 to get a lock.
