Yesterday it hung while doing a recording, will it be HDD problem?. The crashlog is enigma2_crash_1389468113.log
The other I've caused me, because it always hangs at that point, is it a bug image?. The crashlog is enigma2_crash_1389480012.log
Thanks.
1. I think HDD problem
broken startcode
broken startcode
broken startcode
broken startcode
crc32 failed! is 4221fe0a
crc32 failed! is 90653a2e
crc32 failed! is f5b5cecc
crc32 failed! is d141ecdb
crc32 failed! is fd6c7ab4
2. Which point ?? What were you doing ?
Where have you had the EPG data ?
broken startcode
broken startcode
broken startcode
broken startcode
1) thank you, it was what I thought, I have initialized the hard drive, I hope that the problem is corrected with this maneuver.
2) I wanted to send the crash for you to check if there is a problem in the version. The exact site where it is produced is in the MultiEPG, you select a different channel to which you are viewing and the "Zap" button is pressed.
Best regards.
Best regards.
I have test Zap in MultiEPG with default skin and also with Black Shadow3 skin i think you have or you use and no crash .
If you have the EPG on the HDD with problems, maybe this is the reason.
Or something else.
