BH 2.0.8.1
Clive Axisa
Hi
Lately a friend of mine installed the BH 2.0.8.1 on my vu solo2, everything went fine except that I noticed that some of the remote control functions changed. When I press Ok the channel list appear and the < > on the remote switch from one bouquet to another . I can onlyswitch channel in the same bouquet using the up and down buttons.
The channels + and - will open the channel list. etc
quite confusing
Is there a way to set it as it was before.
Thanks in advance
Clive
Probably your friend has installed a plugin like Pauli Neutrino Keymap.
Try to remove it by BH uninstall addons panel.
