bh 2.0.8 fan control issue?
kujrv1
I see temperature is about 43ºC and rpm fan is not avilable in diaplay. I go to fan control plugin, change rpm and save so it begin to start fan and temperature goes down to 35ºC. When i standby and wakeup de vu+ solo2 rpm fan goes to not avaliable and temperature up to 43ºC.
Have one question what fan, all the images and even when I installed my hard drive there is no fan inside the casing can someone explain this fan control please
VU+Solo2 running BH2.0.8.1
I had the same question
I looked everywhere and did not see a fan
my HDD temperature is showing as in YELLOW around 40degrees
Where you have not seen the fan
Inside the box?
what is on the right side
looking at from behind ???
