BH 2.01V bug system crash with parent lock
thameur101
Dear all after cheking many times the parent lock i founf this bug
if i set black list chanels and i set time to save the pin ( 5 o, 30 or 60 min) i load the chanel the i put the pin to open the system crash i try with all setting only never save pin and save next reset are working but when i use time the system crach
hi ok next time i will do my best to send crash log the good news i test with new revision 2.0.1 rev A is ok now thank you for the BH team i will do the test today and i will do my best to advise the team by they way i have one request to ower team
for the light setting oo my ultimo if you can add new setting fir the light whe we use standby mode i want to reduce light. because now when you set light option is affecting both mode normal standby mode thx for BH :thanks:
