BH 2.1.0 Teletext BUG ???
slaroni
I just installed BH 2.1.0 to my solo2 and everything works fine and pretty fast.
But there is one Problem, using Teletext does NOT work correctly.
Opening side100 appears , but there is no response of IR.
no numbers and even Exit is not working for me.
Can anyone have a look on this. maybe it depends on something i installed.
Thanks for great work.
Blackhole 2.1.0 Solo2 when selecting Teletext not working remote control buttons. You have to turn off the box with the switch on the box, and restart it again. But Teletext does not work to use so what's wrong?
Ok there is a workaround to get teletext working for those that need it.
telnet into your box and then type the command
opkg update
and press enter.
Then type the command
opkg --force-overwrite upgrade
and press enter again.
When it has finished, reboot your box and teletext will be working.
