BH 2.1.3 diseqc tester
aligator638
Hello,
I installed my duo2 with BH 2.1.2, set it up and tested with diseqc tester. This worked.
Now I installed 2.1.3, and the tool says, "not tested" for all transponers selected, therefore no test is performed.
So I installed a VTI image, version 7, setup the box, and the diseqc tester works fine.
I guess a problem specific to this version of BH, could anyone check ?
Thanks,
Eric
I tried today with a vuplus version vuplus-image-vuduo2-20151213162454_usb and the diseqc tester plugin works. Next I reset the box to factory and loaded BH
blackhole-2-1-7-vuduo2_usb_release_20150707_c6f93e5-zip.22195
Try the diseqc tester plugin, and it fails for all transponders and satellites. I use a clean image, without any modification except for setting up the tuners (simple/A/B/C/D, 7E,13E,19E).
Can anyone confirm this plugin is not working with Blackhole on Duo2 ?
Thanks
