I'm experiencing the same problem on my setup. Playback from CIFS mounts using the internal mediaplayer causes frequent freezes. This was newer an issue on versions prior to 2.1.0.
If you can, use NFS that is the standard de-facto for file client/server communications
I have the similar problem.Initial tests with NFS shares shows the same symptoms, but the duration of the freezes are much shorter and they appear less frequent. Something changed with the 2.1.0 release and both CIFS/NFS support seem to be affected.
I can confirm that BH 2.1.4 cured network problems with Solo2.I have the similar problem.
I have Solo2 connected through GBE switch to Synology DS213.
I chose BH image because it perfectly supports Sony’s PlayTV DVB-T dual tuner.
When I installed any newer image BH 2.1.x (with new kernel 3.13.5) my network slowed significantly, for example playback of recorded movie from Synology mounted with CIFS has frequent freezes. I reflashed BH 2.1.0,1 and everything is OK.
The similar problems specific only to certain versions of the Solo2 were observed with VTI 7.0 image and Vuplus team released patch of kernel yesterday.
There is very long thread on the VTI support page dedicated to the slow network with kernel 3.13.5 and Solo2.
