BH 2.1.5 remote power on problem
RedCat
Hello
I have Vu duo 2, and I install 2.1.5 BH image. All are fine, but I have one problem: If I shut down the vu+ (dont stand by, shut down) with remote, then I cant power on with remote. The STB start only with power button on device, with remote dont. Why?
On 2.1.4 it was works...
Hello
I have BH 2.1.5 and I have no problem putting the duo2 on standby and turning it back on via the hand control, also I can shut it down via the hand control and turn it back on. All options work correctly in this area. By the way did you do a clean new install of 2.1.5 or a personal backup of 2.1.4 then dumped your setting back in 2.1.5
I have problem with deep standby. If I putting the duo2 to deep standby, then I cant wake up with remote control. Only power button on the vu...
I did new clean install and I set all settings manual.
