BH 3.0.9L+ and Hauppauge pctv nanostick t2 290e usb-tuner
superglud
BH Lover
BH3.0.9L+
After online update today .. (55 packages)
My "Hauppauge pctv nanostick t2 290e usb-tuner" is no longer recognised
Best regards
Duo2 configuration:
Tuner A: Vuplus DVB-S NIM(AVL6222) (DVB-S2) - slot A
Tuner B: Vuplus DVB-S NIM(AVL6222) (DVB-S2) - slot A
Tuner C: Vuplus DVB-S NIM(AVL6222) (DVB-S2) - slot B
Tuner D: Vuplus DVB-S NIM(AVL6222) (DVB-S2) - slot B
Tuner E: PCTV 290e - USB port (Not present in the tuner setup)
Tuner F: PCTV 290e - USB port (Not present in the tuner setup)
Usb Tuners are located in separate USB ports on the back (usb power y cable is wired, between the two USB ports on the back)
Related links
http://www.vuplus-community.net/boa...anostick-t2-290e-usb-tuner.26234/#post-200500
http://www.vuplus-community.net/boa...anostick-t2-290e-usb-tuner.19659/#post-180258
  • dvb_debug_duo2_bh309L_20200711.txt
superglud
BH Lover
FYI:
Somehow the DVB-T/DVB-T2 channels is still selectable in the channellist
When trying the DVB-T/DVB-T2 channels the Duo2 is crashing.
Best regards
  • enigma2_crash_1594446449_BH309L_Build20191124_VuDuo2.txt
  • enigma2_crash_1594446547_BH309L_Build20191124_VuDuo2.txt
warzlh
I have the same problem with uno 4k SE and DVB-T usb Vuplus Turbo.
Many people have problems with this latest update.
