Timeshift, the real timeshift, has NEVER been part of the image by default: you need to install it from the BH server (Permanent Timeshift v1.0.0. Final).
So, the behaviour you report is normal.
Only installing the plugin you'll have the REW/FF features.
Yes this is correct, there ara 2 updates with no change of versions.
I updating by pressing Green button=> yellow button and then Online BH image update
So I suggest to try this way
Have you got any tutorial how to make multiboot on VU+ 4k SE?OMB=Open Multiboot, but it's not pertinent to your case I mentioned just so, on the go.
