BH addons description for 1.7.8 and for mytube stability
van12
For mytube/youtube stability see the bottom of this thread.
Green button - > addons -> addons download manager
I try to find a description for Blackhole/enigma2 addons, but found nothing. I create a short one I want to share . Right now I use only 3 addons: 1channel, coolTv, mytube
1channel: a la netflix, lot of tv show. GOOD
Cool TV: GREAT EPG TV program guide
Advanced Movie Selection: selection of films for OE 2.0 ??
Mytube fix: fix "green screen" mytube, works great
Bild online: germany Bild magazine, not work
Daily motion: like 1channel, but it crashes everytime
Air player: apple's airplay protocol ??
Digital fernsehen: tvguide for Germany
enhanced movie center ??
Media player deluxe: bad, can't mount USB automatically (for a 2.5" usb disk, use the USB backfront; 500mA). Instead use the "Media player" from main Menu, it has many decoder and the subtitles works
Movie time: like "Daily Motion", crash everytime
Multi Quick button: it destroy mytube (green screen), can't repair no matter what (uninstall/reinstall, /usr/lib/enigma2/python/Plugins/Extensions, /usr/uninstall, restore from personal backup) . NEVER USE IT. I need to reflash BH1.7.8 again and then restore (my personal backup on USB) the channels/bouquets
Planar: your schedule, timeplan
FOR MYTUBE stability: never install "Multi Quick Button", see above. MQB overwrites maybe some libraries you never could restore/reinstall again, only a reflash help.
My 3 addons: 1channel, coolTv, mytube works fine together, I had now created a "BH Full Backup" in case if other addons destroy my BH as MQB. But I think I will stick to those 3 addons for sometimes.
GL.
van12
Some more plugins overview from
http://translate.google.com/translate?sl=de&tl=en&js=n&prev=_t&hl=da&ie=UTF-8&layout=2&eotf=1&u=http://www.systemengineers.de/dreambox/plugin/uebersicht
