Sturlus stugi
Hi, i get this GSOD when trying to enter menu -> plugins -> (red button) manage extensions.
Any idea what is wrong??
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Mon Mar 4 13:27:58 2013</crashdate>
<compiledate>Feb 17 2013</compiledate>
<contactemail>crashlog</contactemail>
<skin>MX_HD2/skin.xml</skin>
<sourcedate>2013-02-17</sourcedate>
<branch>vuplus_experimental</branch>
<rev>exp-2010.12-1025-ga0a1fbc</rev>
<version>3.0.0</version>
</enigma2>
<image>
<dreamboxmodel>dm500hd</dreamboxmodel>
<kernelcmdline>bmem=144M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201302161754
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.0.0 %h
</imageissue>
</image>
<software>
<enigma2software>
<!-- Cannot allocate memory -->
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
ok
start release channel timer
not pauseable.
RemovePopup, id = ZapError
use cached_channel
stop release channel timer
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:19:EDF:26:46:E070000:0:0:0:
no version filtering
0012: 4e 0e df 00 00 00
mask: ff ff ff 00 00 00
mode: 00 00 00 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
eventNewProgramInfo 0 0
have 1 video stream(s) (0200), and 1 audio stream(s) (0280), and the pcr pid is 0200, and the text pid is ffffffff
disable teletext subtitles
PES filter: DMX_SET_PES_FILTER - Invalid argument
decoder state: play, vpid=512, apid=640
DMX_SET_PES_FILTER(0x200) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x280) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 1 - ok
DMX_SET_PES_FILTER(0x200) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[AutoRes] service changed
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
+ 1/1 TID 00
done!
PATready
use pmtpid 010e for service_id 0edf
010e: 02 0e df 00 00 00
doing version filtering
0000: 00 00 00 25 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
-+ 1/2 TID 4e
+ 1/1 TID 02
done!
have 1 video stream(s) (0200), and 2 audio stream(s) (0280, 0281), and the pcr pid is 0200, and the text pid is ffffffff
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
[eDVBCAService] new service 1:0:19:EDF:26:46:E070000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:19:EDF:26:46:E070000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
[eDVBCAService] send 65 bytes
9f 80 32 3d 03 0e df 0f 00 19 01 81 08 0e 07 00 00 00 26 00 46 82 02 01 00 84 02 01 0e 09 04 0b 00 e0 64 1b 02 00 00 00 04 02 80 00 00 06 02 81 00 00 06 02 62 00 00 06 02 63 00 00 06 02 64 00 00
010e: 02 0e df 0f 00 00
mask: ff ff ff 3f 00 00
++ 2/2 TID 4e
done!
0012: 4e 0e df 3b 00 00
[AutoRes] determineContent
action -> InfobarChannelSelection zapUp
playing 1:0:1:9D4:A:46:E070000:0:0:0:
[eDVBCAService] free slot 0 demux 0 for service 1:0:19:EDF:26:46:E070000:0:0:0:
[eDVBCAService] free service 1:0:19:EDF:26:46:E070000:0:0:0:
decoder state: play, vpid=-1, apid=-1
DEMUX_STOP - pcr - ok
DEMUX_STOP - video - ok
VIDEO_STOP - ok
AUDIO_STOP - ok
DEMUX_STOP - audio - ok
AUDIO_CONTINUE - ok
not pauseable.
[eDVBCAService] remove channel 0x734f2d58
[eDVBLocalTimerHandler] remove channel 0x734f2d58
[eEPGCache] remove channel 0x734f2d58
allocate channel.. 000a:0046
[eDVBCAService] new channel 0x1a1e1b8!
(0)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 0 Freq 10934000 Pol 1 SR 24500000 INV 2 FEC 5 orbpos 3591 system 0 modulation 1 pilot 2, rolloff 0
tuning to 1184 mhz
OURSTATE: tuning
[eDVBCIInterfaces] addPMTHandler 1:0:1:9D4:A:46:E070000:0:0:0:
allocate demux
[SEC] set static current limiting
[SEC] setTone 0
[SEC] sleep 25ms
[SEC] setVoltage 1
[SEC] sleep 20ms
BlackHoleapi: popclose,
set sequence pos 3
[SEC] invalidate current switch params
[SEC] sendDiseqc: e01038f4
[SEC] sleep 50ms
set sequence pos 3
set sequence pos 3
[SEC] update current switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
(0)fe event: status 0, inversion on, m_tuning 1
(0)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x1a1e1b8 running
[eDVBLocalTimerHandler] channel 0x1a1e1b8 running
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
[eEPGCache] channel 0x1a1e1b8 running
[EPGC] next update in 2 sec
0012: 4e 09 d4 00 00 00
have 1 video stream(s) (0202), and 1 audio stream(s) (028c), and the pcr pid is 0202, and the text pid is ffffffff
allocate demux
decoder state: play, vpid=514, apid=652
DMX_SET_PES_FILTER(0x202) - pcr - ok
DMX_SET_PES_FILTER(0x28c) - audio - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
VIDEO_SET_STREAMTYPE 0 - ok
DMX_SET_PES_FILTER(0x202) - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[eDVBLocalTimerHandler] diff is 0
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] not changed
-+ 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
use pmtpid 0103 for service_id 09d4
0103: 02 09 d4 00 00 00
0000: 00 00 00 1d 00 00
+ 1/1 TID 02
done!
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
[eDVBCAService] new service 1:0:1:9D4:A:46:E070000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:9D4:A:46:E070000:0:0:0:
[eDVBCAService] send 45 bytes
9f 80 32 29 03 09 d4 01 00 19 01 81 08 0e 07 00 00 00 0a 00 46 82 02 01 00 84 02 01 03 09 04 0b 00 e0 64 02 02 02 00 00 04 02 8c 00 00
0103: 02 09 d4 01 00 00
[SEC] set dynamic current limiting
++ 2/2 TID 4e
done!
0012: 4e 09 d4 2f 00 00
sdt update done!
[EPGC] start caching events(1362400042)
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
ERROR reading section - Value too large for defined data type
poll: unhandled POLLERR/HUP/NVAL for fd 31(8)
action -> InfobarChannelSelection zapDown
playing 1:0:19:EDF:26:46:E070000:0:0:0:
[eDVBCAService] free slot 0 demux 0 for service 1:0:1:9D4:A:46:E070000:0:0:0:
[eDVBCAService] free service 1:0:1:9D4:A:46:E070000:0:0:0:
VIDEO_STOP - ok
AUDIO_STOP - ok
AUDIO_CONTINUE - ERROR reading section - Value too large for defined data type
ok
not pauseable.
[eDVBCAService] remove channel 0x1a1e1b8
[eDVBLocalTimerHandler] remove channel 0x1a1e1b8
[eEPGCache] remove channel 0x1a1e1b8
[EPGC] abort caching events !!
allocate channel.. 0026:0046
(0)tune
prepare_sat System 1 Freq 11785000 Pol 0 SR 30000000 INV 2 FEC 3 orbpos 3591 system 1 modulation 2 pilot 2, rolloff 1
tuning to 1185 mhz
OURSTATE: tuning
allocate demux
set sequence pos 3
[SEC] setVoltage 2
[SEC] sleep 20ms
set sequence pos 3
[SEC] sendDiseqc: e01038f7
[SEC] sleep 50ms
set sequence pos 3
[SEC] setTone 1
[SEC] sleep 10ms
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
(0)fe event: status 0, inversion off, m_tuning 1
(0)fe event: status 1f, inversion on, m_tuning 2
OURSTATE: ok
[EPGC] next update in 56 min
allocate demux
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
+ 1/1 TID 00
done!
PATready
+ 1/1 TID 02
done!
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
-+ 1/2 TID 4e
sdt update done!
++ 2/2 TID 4e
done!
action -> CoolTVGuideActions CoolMenu
unknown action CoolTVGuideActions/CoolMenu! typo in keymap?
action -> InfobarMenuActions mainMenu
loading mainmenu XML...
BhRed BhRedp_main
BhSettings DeliteSettings
PluginBrowser PluginBrowser
BhAddons DeliteAddons
BhEpgPanel DeliteEpgPanel
TimerEdit TimerEditList
allocating new converter!
action -> OkCancelActions ok
okbuttonClick
warning, skin is missing element green in <class 'Screens.PluginBrowser.PluginBrowser'>
action -> ColorActions red
[ePopen] command: ping -c 1 82.149.226.170
[ePopen] command: ping -c 1 193.99.144.85
[ePopen] command: ping -c 1 209.85.135.103
child has terminated
pipes closed
executing opkg update
pipes closed
poll: unhandled POLLERR/HUP/NVAL for fd 55(16)
poll: unhandled POLLERR/HUP/NVAL for fd 58(16)
no ancillary data in audio stream... abort radiotext pes parser
pipes closed
poll: unhandled POLLERR/HUP/NVAL for fd 61(16)
data: Downloading http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Inflating http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Updated list of available packages in /var/tmp/official-3rd-party-settings.
Downloading http://feeds.vuplus-community.net/2.0.0/all/Packages.gz.
Inflating http://feeds.vuplus-community.net/2.0.0/all/Packages.gz.
Updated list of available packages in /var/tmp/official-all.
Downloading http://feeds.vuplus-community.net/2.0.0/mips32el/Packages.gz.
Inflating http://feeds.vuplus-community.net/2.0.0/mips32el/Packages.gz.
Updated list of available packages in /var/tmp/official-mips32el.
Downloading http://feeds.vuplus-community.net/2.0.0/vusolo/Packages.gz.
Inflating http://feeds.vuplus-community.net/2.0.0/vusolo/Packages.gz.
Updated list of available packages in /var/tmp/official-vusolo.
pipes closed
[ePopen] command: opkg list
poll: unhandled POLLERR/HUP/NVAL for fd 59(16)
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 4726309 bytes for cache used
File "/usr/lib/enigma2/python/Tools/BoundFunction.py", line 9, in __call__
return self.fnc(*self.args + args, **newkwargs)
File "/usr/lib/enigma2/python/Components/Console.py", line 46, in dataAvailCB
self.appResults[name] += data
MemoryError
(PyObject_CallObject(<Tools.BoundFunction.boundFunction instance at 0x72ceb418>,('t-plugins-base-videorate - 0.10.36.1+git10166+95c3841-r1 - gst-plugins-base version 0.10.36.1+git-r1\n GStreamer plugin for videorate\ngst-plugins-base-videorate-dev - 0.10.36.1+git10166+95c3841-r1 - gst-plugins-base version 0.10.36.1+git-r1\n GStreamer plugin for videorate (development files)\ngst-plugins-base-videoscale - 0.10.36.1+git10166+95c3841-r1 - gst-plugins-base version 0.10.36.1+git-r1\n GStreamer plugin for videoscale\ngst-plugins-base-videoscale-dev - 0.10.36.1+git10166+95c3841-r1 - gst-plugins-base version 0.10.36.1+git-r1\n GStreamer plugin for videoscale (development files)\ngst-plugins-base-videotestsrc - 0.10.36.1+git10166+95c3841-r1 - gst-plugins-base version 0.10.36.1+git-r1\n GStreamer plugin for videotestsrc\ngst-plugins-base-videotestsrc-dev - 0.10.36.1+git10166+95c3841-r1 - gst-plugins-base version 0.10.36.1+git-r1\n GStreamer plugin for videotestsrc (development files)\ngst-plugins-base-volume - 0.10.36
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
