BH Teleportation
Hi
Seen this on my menu, what is this option used for? Is it worth while setting up?
Thanks
If you've read anything on here m8 about universes this is what it is. Basically you have to format and mount USB for universes then you live in one of them. I.e your flash is the same size as your USB device. Handy if you use a lot of plugins if you have a duo etc.
