BH .ts recordings
jfim88
Hello!
I'm testing with record function on my Solo 2 with BH 2.1.1. It records excellent and can view another channel without problems...
The record is a .ts file. How do you convert to another format? For example avi or mkv. What programs do you use?
Thanks!
There are a lot of programs which can convert .ts file BUT! I recommend to use TSMUXER. It is FREE and convert in M2TS or Blu-Ray format (or simply demux...). The VERY important thing about TSMUXER is that it doesn't recompress the file. It simply change the container. So, you don't have loss of quality!
And can convert into mkv for example?
Enviado desde mi Nexus 5 mediante Tapatalk
