BhPersonalBackup package
lorenzo64
Black Hole team want to help users that wants to install the new image using immediatly the new personal backup function.
For this reason here is the package working on the previous BH images too.​
You can install this package on BH 1.6 or older, make personal backup, flash the box with the new BH 1.6.1 and then restore all your stuffs.​
I've just posted this in the Image thread, I'll put it here as well so the relevant developer may see it quicker.
One thing that wasn't 100% was the OpenVPN, image started with the default config rather than the custom config that I use. I would suggest that the plugin deletes the contents of the /etc/openvpn folder before restoring the backup. It also didn't restore the CrossEPG settings. But overall, it was much easier than using the standard software backup/restore and is very welcome :)
There was a problem when restoring 1.6 settings to 1.6.1
MultiQuickButton plugin didn't work, missing .xml files error when pressing remote buttons.
After reinstall MQB, everything was fine again.
Hello i have a question about this featured.
When i restore my backup i must configure the cros epg again. this the crosepg not included in the backup???
thanks a lot
-David
No. We need to configure Crosepg again. If this can be fixed will be great.
This "issue" is choosen by BH plugin author because the CrossPEG configuration can change without warning from one version to another and cause problems and crashes.
For this reason the backup of crossepg configuration is not included into backup.
