indbyggeren
Hallo,
I have just installed BH 2.1.7 om my DUO2.
But but but, now i can´t record one scramblet channel and se another at the same time.
My tuners seems to be workig.
I have 2 seperate tuneres, A+B with loop. but i run with two cables from the LNBs.
When i want to se a channel the A tuner is operating, and if i press record, it will record as it should.
BUT when i try to watch another scramblet channel i can not se it! the screen is black. on the screen the A tuner is red, and the B tuner is Blue.
That tells me that the VU is using the B tuner as it should when i doing a record on tuner A.
I dont understand the problem?? it have work for me before, but after update to BH 2.1.7 it will not work.
Is it a config fail in the cam/server? is there some limitations in the BH image.
I can se that other have the same problem, but does anybody know what to do??
