BIGTec 120 [RT5370] on BH 1.7.4?
buran00
Hey Guys,
I cant get my Stick to work with the newest image 1.7.4.
I always get the message, that the module is invalid or something.
I tried to install rt3070_2.5.0.2-r4_bm750.ipk manually by extracting the module and loading it, but then I get the message 'Invalid Module Format', so its not compatible I suppose.
Is there a compatible driver I can use, and if yes, where do I get it from?
Thanks in advance for any help,
buran00
Hey Guys,
buran00
What box do you have?
To investigate I need the USB IDs of your device.
I'm using the VU+ Duo Box.
I hope I'm delivering you the right information now:
USB\VID_148F&PID_3070&REV_0101
Thats the ID I get in DeviceManager on Windows.
The Box displays it as 5370, I dont know what to believe :)
