bitbake, a little help please
martinoff
hi
i have successfully build an image for vuduo from makefile
after some reading on openembedded wiki and bitbake
make some changes in bootlogo.bb and skin, i clean this with
bitbake -b bla-02.bb -c clean
after that build them again
all works without error
try to build again the images with
bitbake -b ../enigma2-image.bb
again it is build without error but my bootlogo is default and not the one i build
what i am doing wrong ?
is this way the right one or i have to made all the changes and build the image from begining ?
how we can make change in the image, with plugins of my choice etc ?
with debian testing (python2.6.7) in the first try of building the image i get some error for python_2.6.6.bb but if i run again the bitbake then compile the image successfully and without errors
Hi,
i'm new in Vu+ compilation, i'm learning ;)
But what i understand, it' that you have to built vuplus-image with :
bitbake -c build vuplus-image
Because, it have to rebuilt the "rootfs" with modified files and then it will create the jffs2 files, bin file, vmlinux file and then make the nfi file.
