Bitrate plugin not work
a_zero_4k
Hi
Installed from server open black hole
But it does not work
Only the audio streams
Video streaming is not working
Vu + zero4k
Photo: Open Blackhall
How do you make it work؟
Never had any problems with this plugin neither by OpenBlackHOLE nor by BH: claiming it does not work it's a little bit... exaggerated ;)
Does this happen with every channels? Have you checked that? I hope is not an IPTV channel...
As far as I remember it doesn't work on Zero 4K
nor with a single image.
It's an old problem. I don't think it's ever solved.
It is a real channel, not iptv
All imege were tried without success
Look at the attached picture above, you will find that the video values are zero
Can I find a backup for the vu+Zero4k device Includes Bitrate Works
make it work again
As far as I know it never worked on Zero 4K
And it may never work
probably related to drivers and different tuner.
Working with cable tuner but not with S2X tuner Zero 4K
the tuner bug still has not been fixed (if even possible) by VU+
...And, above all, if it doesn't work under any images, it's not related to them but, in case, only the plugin's author can fix it and must be contacted, for instance opening an issue on his GitHub repository, not here.
