Have tried to flash the new Black Hole 1.6.5 several times on my VU DUO, but gets repeting problem when trying to download via addon server. It works alright until I try to download any plugin, then it crashes.
I’m able to access the addon server and able to browse the content. But when trying to download, the screen goes black and a few second later “green screen” and restart.
As far as I can see in the chashlog, it seems to be related to the default skin?? Not an expert on this, but that is what I can read in the crashlog!
The is an extract from the crashlog:
File "/usr/lib/enigma2/python/mytest.py", line 201, in processDelay
callback(*retval)
File "/usr/lib/enigma2/python/Blackhole/BhAddons.py", line 362, in connectionDone
File "/usr/lib/enigma2/python/mytest.py", line 312, in open
dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 247, in instantiateDialog
return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
File "/usr/lib/enigma2/python/mytest.py", line 272, in doInstantiateDialog
readSkin(dlg, None, dlg.skinName, desktop)
File "/usr/lib/enigma2/python/skin.py", line 486, in readSkin
raise SkinError("component with name '" + wname + "' was not found in skin of screen '" + name + "'!")
skin.SkinError: {skin.xml}: component with name 'key_yellow' was not found in skin of screen 'Nab_ShowDownFile'!
(PyObject_CallObject(<bound method Session.processDelay of <__main__.Session instance at 0x194bbe8>>,()) failed)
I even tried to manual install an other skin, but this also resulted in crash and never ending restart/green screen. Had to kill the power and re-flash the image again!!!
Anybody out there which have installed this image on a DUO and are able to download plugin?
Or anybody able to read the crashlog and tell me what’s wrong and how to fix it?
Kindly.
callback(*retval)
Kindly.
