Black Hole 2.0.2 rev. C
No it is not an issue.
In vuplus git satellites.xml was changed and updated so it is normal that the upgrade changes it with the newer version.
I have had to go back to rev. A as there was a problem receiving high band channels on tuner A. e.g. Sky News on 28.2E 12.207 V after updating to rev. B & C. Dish alignment was OK as I have another box connected to the same dish. No matter what I tried the LNB would not change to high band.
Have any others experienced the same problem?
Since writing the above I have installed rev. C again and this now seems to be working without problems.
i done the online upgrade from b to c last night and i could not get anything to work not even from there server i went back to b which im running now im going to wait awhile untill i do another upgrade to make sure it stable. i have asked about this on the board but got no fed back only what you have put is the time right now aswell.
I just came home, after a weekend trip
and after image update
all OK
Time zone OK
tested channel Sky News on 28.2E 12.207 V OK
I use @Likra SAT list.
After upgrade, i have green screen on EPG.
EPG data corrupted ... the image has nothing to do with that. I suppose you use CrossEPG for EPG system... I'm right?
BH 2.0.2 C has been problematic from the day one of its release. The sooner we have 'D' version, the better.
On my Solo2 all works regularly with Rev C ..... If you have rpoblems, post a crashlog first.
Thats right, I have CrossEPG, and what i tried to do:
delete all base CrossEPG, restart, download EPG - nothing changes,
I put empty providers list CrossEPG, and copied from CrossEPG to the root of hdd xml.epg.dat renamed to epg.dat(cause i didn't locate it there).
So for now without CrossEPG.
This is not so
You have broken image and CrossEPG.
Of course you do have enigma crash.
ReInstall image
and do not touch CrossEPG and epg.dat.
Okay, will follow topic u mentioned, but i doubt about it's not connected stuff, if it is a part of image ...
And thank you very much for help.
EPG is part of the image.
But EPG data coming from the server which maintains Rytec team.
CrossEpg is external plugin which we have not make.
In addition there are hw memory limitations of older boxes.
I can only tell you
I tested several times I downloaded all Rytec epg providers with Solo2
and it worked without enigma crash.
In cases where a crash enigma, which has also been
cause lay in a damaged epg.dat with wrong information,bug.
So I am absolutely sure
that in cases where the conditions are met,
requiring enigma to work , EPG works 100%.
In cases where it is not, enigma activates protective mechanism
and that is enigma crash, and deleting poor epg.dat.
