Ev0
Admin
Black Hole 2.1.1
By Black Hole
- New skin MX SkyLine SE
- Add new Crypto systems in OSD: Biss, Bulcrypt, Betacrypt, PowerVu (By Ev0)
- Add parental control in Bh extra settings panel
- HbbTV enabled by default for Duo2, Solo2, SoloSE, Ultimo
- Removed mytube plugin (can be installed from BhSpeedUp)
Kernel:
- Update Kernel 3.13.5(solo2, duo2, solose)
- Update Kernel 3.9.6(duo, solo, uno, ultimo)
20140715(duo, solo, duo2, solo2, solose)
20140716(uno, ultimo)
- - Support SoloSE
- - Switch to Kernel 3.13.5 (solo2, duo2, solose)
- - Switch to Kernel 3.9.6 (duo, solo, uno, ultimo)
- - Fix sound drop in radio channel
- - Improve PIP (solo2, duo2, solose, Needs E2 update)
- - Allocate more memory to linux (duo2)
- - Improve media playback
- - Fix vfd problem
- Update r8192cu (4.0.2)
- Update bridge-utils (1.4 -> 1.5)
- Set sync PCR at PIP mode.
- fix duo harddisk detection
- [hbbtv] fix UI position
- [hbbtv] upgraded to 'opera-hbbtv_0.2.bb'
- disabled copy libs to sysroot
- [hbbtv] reduce CPU usage
- [hbbtv] fix ipc protocol
- [hbbtv] fix flickering some channel.
- support seeking the recorded video
- lcd4linux: update to 4.1-r2
