Black Hole 2.1.5
Ev0
Admin
Black Hole 2.1.5​
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
Note for Meoboot and OpenGL images:
Because OpenGL images have a different boot procedure and the framebuffer is loaded at the end of rcS it is not possible to have the Bootmenu.
For this reason to change image you have to go into Meoboot plugin, select the image you want to boot and click on "Boot Image" button.
vu+ new release215.png​
