Black Hole 2.17
How can I delete the recordings from the hard disk ?
If you have a large amount of files to delete on your HDD, the best way is:
Using an FTP software ( Dreambox Control Center, Filezilla, WinScp, ... ) and navigate to /hdd/media .
You´ll find your recordings there as your medias too ... select all files you want to erase and press delete on your keyboard.
and when not can use the software ? Can delete files direct to my vu ?
On Mediaplayer --> will do the job --> when you are under the name of the recording you want to delete!
Open your Player
Move to over the file you want to erase.
On under the name of recording --> Press MENU --> Choose DELETE to erase the selected file!
