Black Hole 3.0.1.F Vu+ Duo2 OE 3
Ev0
Admin
Black Hole 3.0.1.F OE 3
update driver(solo4k)
20160119
- Support Chromium OS
- Fix DiSEqC problem
- Improve power consumption
- Fix misc.
Chromium OS added (solo4k)
Youtube Tv added (solo4k)
Fix RC key position on help menu.
Fix tuner Loopthrough issue
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thank you for the effort, but not compatible with CI Moduł NC+ MIX. Depczę na miejscu na BH Image v2.1.5 ! :wallbash:
Very nice, thank you :thanks:
I tested all the images, but BH has the most beautiful picture and best design no matter which skin is used. Only two things I miss in BH (or I do not know find).:(
1: Customize channel list cursor behavior (keep service) and
2: Get automatisk subtitle when starting a movie with harddisk which has a separate translation.
Hello, I use vu+ duo 2 (4 LNB input) have official access card, why can not I get over 7 channels simultaneously? 4 transponders. 8 and more channel have not already imaging.
thanks
Thank you for the great image!
I am having problems updating plugins under extensions management I see a message that 22 updates are available but when I try to update nothing is updated.
I also tried updating image through Adonis management (green yellow) also nothing is updated.
Can you look into it?
Regards
