Black Hole 3.0.1 Vu+ Duo OE 3
lorenzo64
Black Hole 3.0.1 OE 3
Dear Vuplus-Community users,
The Black Hole Team are proud to announce, the new Black Hole 3.0.1 image based on the new Vu+ OE3.0 for all Vu+ models.
This new Black Hole 3.x image includes all the features of the previous Black Hole 2.x series, but also adds the foundations for new features in the future.
Please be aware that there are currently issue's preventing the Vu+ Turbo usb tuner from working with the Vu+ Solo, Duo, Uno, Ultimo and Zero models, we hope to resolve this issue soon.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Nice work, but wlan is not working. Message: "The wireless LAN plugin is not installed! Please install it."
I have an original VU WLAN dongle. This has never been a problem before. How to solve this problem?
Use Wireless Lan Setup in System menu to config wireless.
no connectivity. I am using wired LAN
when you have dhcp off please try it and then reboot
openmultiboot
wrong image in flash ?
3
3
I like the way some have time to edit posts
but have no time to answer them
anyway here is a workaround network with DHCP off
I only have this installed in flash no HDD or usb
and I get
sorry wrong image found in flash. you have to install
the Black Hole image in flash 3.0.1
Teletekst is not working for me on my Vu+ Duo. :(
Install this new image twice but with no good results.
Teletekst button give no responce on my two remote controls.
Thx for the hard work for the image but i am back on image 2.1.7/01
Hi there.
Thanks for this new release. It seems to be a great work, again!!
After upgrading, I get the following error message start the SBOX EMU:
/usr/bin/sbox: error while loading shared libraries: libpcsclite.so.1: cannot open shared object file: No such file or directory
Having a look at /lib I see no file/link named as "libpcsclite.so.1", which apparently it is used by the EMU.
May you please help me?
