Black Hole 3.0.2.A Kodi Vu+ Duo2
Ev0
Admin
Black Hole 3.0.2.A Kodi​
What is new ?​
- update driver(solo4k)
- Add proc entry to support some unicable equipments(needs a Solo4k Misc. plugin)
- Add proc encry for DVB-CI timing control(needs a Solo4k Misc. plugin)
- Fix misc. bugs
- [Solo4kMiscControl] add new plugin.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
With this online update, on 1081i and 1081p, Kodi is still in the left corner of the screen, or am I doing something wrong.
Now this image works for me, I don`t know why, but it is OK now. Thanks BH. You are the best
Its not showing as MiscControl plugin in green panel in VU+ Duo2,..its only option for download such its Main Menu->Plugins->Manage extension/red button,
and when its download,and restart E2,shows as plugin but its unvailable as shows as on picture"Driver is not supported".,as its for Solo4K.
The plugin MiscControl is for VuSolo4k only.
Sorry yes my mistake, it is a solo4k only plugin (it has been a long day already).
It seems that 3.0.2 is not available as an online update of 3.0.1F, am I right? So it must be flashed from scrap and then I can restore settings and plugins from BHpersonalBackup?
New flash, although you can make the use of backup settings.
In any case, i suggest you for make too a FullBackup ;)
Always a full backup and even without any upgrade to do, otherwise I'd been dead for a heart attack ages ago ;)
