Black Hole 3.0.2.E Kodi Vu+ Duo2
Ev0
Admin
Black Hole 3.0.2.E Kodi​
What is new ?​
-Fix Subtitles Autolanguage​
6.jpg​
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
nice work as Always . question anybody that know whats wrong with openwebif to stream to my phone and vuplus playerhd , its works with bh 2.17 and now with bh 3.02 i dont
The subtitles setting dont stick and if i Change skin it loses all setting and also if i redtart the box i have to activate subtitles again .
Hello, I'm new owner VU + DUO2 and has recorded img.VTi 9.0.2., I would try to load your img.pro VU + DUO2 and BH 3.0.2, I have with this new firmware upload DUO2_CFE? and if so, I must first upload and then CFE img, or the first img.a then CFE?
Thank you for the answer.
As I said in another thread, Kodi is totally unuseful via Duo2's analog out, because user interface is not available. Bak luck. Hoping in possible updates.
Must be blackhole . Vuplus thats blackhole is build on works fine
For android phone use "BSPlayer Free". all connecting "flawlessly" as it must be.
Few steps:
  • Connect to your STB inside your network with the parameters required using ( VuPlayer HD downloaded from from Google PlayStore )
  • Download and install from "Google PlayStore" --> BSplayer Free ... ( VLC is not working ... gives you connection timeout )
You'll need the IP of your VU+ STB, or your DynDNS Address
The port: 80
Zapp before streaming --> ON
Username: root
Password: ( Blank field ), not required any password if you haven't set one.
Transcoding function --> OFF
Default Player: ( Assign the installed "BSPlayer Free" )
Save the settings.
Now you should be able to play your media from your android device.
No no it dont work. Unable to connect..
in 2.17 it works flawless. Have The same settings in bh 3.02f on vuduo works perfekt. Does it work for you nunigaia
Vuplus image that 3.02 E and F that bh is build on works fine
As i said, is working for me, OpenBH 04, BlackHole 2.1.7, BlackHole 3.0.1, BlackHole 3.0.2, OpenBlackHole 01, etc ...
The Player "BSPlayer Free".
Strange its wont connect. But if i flash 2.17 its works perfekt same settings
Then please tell me why vuplus image works just fine for me but the one you realesed yesterday dont its the same core isn it
I tested dreamplayer and thats work hm strange.
It strange that vuplusplayer hd works on bh 3.02F for vuduo and not on blackhole 3.02F vuduo2.
If it would be error with du that i could understand.
I don´t know, but for me is working, maybe something is blocking it, in your case. Anyway i only report here this, because there are people that uses it.
I don´t use it, and don´t intend to use.
Thanks will try more later.
i have tried alot but no luck. a question is bh3.02F build on vuplus-image-vuduo2-20160516163757, because vuplusplayer hd works fine on that image
Evo do I have to update the Efc before flashing this I'm currently on vix 3.2 duo 2 I've seen it in really old posts so unsure if still needed
Sent from my SM-G935F using Tapatalk
