Black Hole 3.0.2 + Viaccess Module + Bis Tv = no Rights
foxco00
Dear VuPlus Guru,
I rebuild my Vu+ Solo to Black Hole 3.0.2 from scratch.
-> no backup, no favorites, Nothing.
Since the new version is up and running,
I'm not able anymore to use the Offical card in my Viaccess Module (Slot 1 or Slot 2).
If I try to browse one channel which must be decrypt with the card,
I get an error message related to rights, even if the card is fine and was working few hours ago with a previous Black Hole version.
Do I miss Something ?
Do I have to install some addon ?
I'm able to browse the card and double check rights validity;
but channel is not decrypted and a get a pop-up
Thanks for your help
Error Message :
"Acces non accordee par l'operateur pour le(s) Programme"
Which could be translated as
"Access denied by operator for this(those) programs"
Error Message :
Do you see in Menu-Setup-Common Interface the CAM module and the smartcard rights?
Yes I do, Rights are fine. till 22 (as each month)
I call BisTv;
Answer was : You're making cardsharing. Card is active but locked;
So Seems I have to wait and card will be unlocked after few days ... No idea how many days...
Do You think this could happens due to setup with the PCMCIA and SmartCard inserted ?
I do not make ANYTHING related to cardsharing or assimilated.
One Vu+, One Tv, No port Forwardind to my Box from outside.
Do I have to remove the Gateway from the interface used in the LAN (Record to NAS only)
Thanks
I call BisTv;
Thanks
Uhm .... why your TV provider report that you do CS?
Are you doing similar things or you are using a CI CAM module?
I do not run any *******,
use a default BlackHole image;
I have a Neotion Viaccess Module in slot1...
Card Provider (Not TV Provider) told me I could wait 10 days before getting signal again...
Yes.
Now, Do I have to fight with Bis TV or swap to Fransat for TNT channels ?
-> no card to renew each year...
