Black Hole 3.0.3.G Vu+ Duo
Ev0
Admin
Black Hole 3.0.3.G​
What is new ?​
- update drivers(uno4k, ultimo4k)
- Fix HDMI out problem(idle mode & wake up)
- Fix FBC DVB-C problem
- Fix pixelation problem(ultimo4k)
- Support 4K transcoding in idle mode
- Fix problem when there are 2 transcodings at the same time.(ultimo4k)
- Change recording resolution of HDMI-IN to fixed 720p (ultimo4k)
- update FCC plugin, Fix PIP issue due to FCC
- update FCC plugin, FCC is available only for dvb services (service type == 1)
- update autolanguage plugin to include: Ukrainian and Visual impaired commentary
- update Russian translations
- update usbtunerhelper to help with devices with unknown manufacturer
1-png.28939
3-jpg.28932
4-jpg.28933
5-jpg.28935
6-jpg.28936
7-jpg.28937
8-jpg.28938
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
very nice. how to downloads ?
Hi
I'm very new to this forum and it took me a while to see how to download it too.
There is a box at the bottom of the first post that says "attached files", click the folder and it will down load for you.
when i use this i cant load down blackhole apps
I do not understand what is the problem ?
First post is the image download and not plugins and additions (apps)
They you can download from BH server after image installation ,
from the image and box.
hi iam new to this cool froum can any one tell me an easy and simple way that i can bring this image to my vuplus duo ?i mean is there a manual or some pdf or video for beginers like me☺☺☺
hi again
i have latest openatv on my vuplus duo and it always crashes and the blue screen comes up
now i want to install BH on my device can you tell me how to do it ? sorry because of my dummy questions
hi again
Installing is like in other images to VU+.
If you install before oenpatv go this some way.
hi
i didnt get what you mean
i flashed my device(with routine ways that told on net like copy it to a flash memory and reboot and wait ) with openatv and its crashing always but my question is that can i flash device with bh like the way above that i told
again iam sorry of my dummy question
i have a vuplus duo it has latest open atv working on it but it always crashes iwant to install a bh on my device can you tell me what to do ?
