Black Hole 3.0.4.C Vu+ Duo
Ev0
Admin
Black Hole 3.0.4.C
What is new ?
- Update CrossEPG Providers
- Update [opera-hbbtv] to fix youtubetv transparency issue
1-png.31518
2-jpg.31506
3-jpg.31507
4-jpg.31510
5-png.31514
6-png.31513
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.4-bm750_usb_release_20171018_fa35b14.zip
HarryRoberts
Hi
I'm currently running BlackHole 2.1.5, Build 2015-02-26-master, DVB drivers 20150109, Kernal version 3.9.6 on my VU+ Duo (not the latest Duo2).
Can I install Black Hole 3.0.4.C? If so, what do I need to bear in mind? Is there a tutorial which would help me as it's been a while since I last updated.
Any tips or suggestions would be most welcome.
TIA
Harry
AlexWilMac
Moderator
If the image has been released it means it's possible to install it ;)
But the installing will make you start from scratch either about plugins installed or everything else.
What you can save are the settings (the channels): you can do it by a software like iDreamX for Mac or DreamboxEdit for windows or similar.
HarryRoberts
Thanks for your help... sorry to have asked something so basic.
I'll have a crack at installing it.
AlexWilMac
Moderator
Don't worry, nunigaia! "Have a crack at" means make an attempt to do something, as one fears not to manage it.
Or, also, he meant: it's my turn to install it.
I'm curious: what of the two did you mean, HarryRoberts?
HarryRoberts
I simply meant I will 'have a go' or 'attempt' or 'try' to install it.
Given my limited understanding and ability, it will be an attempt without guarantee of success.
Thanks for the new version.
bugima
Hi, i hope anyone can help me.
I have until now used a Sweex Wireless 54G Adapter on my vu+duo. Its been ok, but i am now thinking of streaming from the box to a tv and i assume this is a bottleneck.
So today i bought a TP-Link AC450 Wireless Nano UDB Adapter. I plugged it in and hoped for the best. Unfortunately, the box did not like it and could not detect it. It came with some error message that no module something could not be found.
So, do i need to install a new driver? Is the driver available in the BH image somewhere, so that i just need to activate it or does it not exist and or can someone help me out?
AlexWilMac
Moderator
Never, never, never buy a device without searching in advance if it's supported by your image! VU+ is managed by a sort of Linux O.S. and Linux is already not so universally compatible with every device in the world! You are not trying to use a device with Windows or OsX, where you have almost always the drivers needed.
bugima
Alex, the TP-Link is supposedly one of the most flexible and reliable adapters with similar speed on the market today. It can go on Mac, PC and Linux. Its probably one of the most popular as well (at least in Norway).
Furthermore i checked which chipset it needs and its something called WI1 chip1:MediaTek MT7610U.
A quick google search (MT7610U + vuduo + Black Hole) and i saw that this driver was included back in BH2.0.7. Hence, i went ahead and bought the device.
I now see that the probable Linux driver is called mt7610u_sta. So maybe there is the problem?? That it is not the same as MT7610U ?
Do you have any suggestion for which wifi adapter i should go for? As mentioned it needs speed which will not bottleneck streaming from the Vu box. Is there a list of devices somewhere?
The purchase did not ruin me, so if there is no way anyone got this driver ill go ahead and buy a new one.
bugima
So, what do we have here... Only one guy who basically tells me im an idiot who buys the most popular linux compatible wireless adapter?
Is there any in the BH team who can state whether its possible to create a lpk file for the driver?
AlexWilMac
Moderator
I didn't tell you anything like you say: I'm not this kind of person. It was only a general recommendation. In my experience of computer and device reseller, TP-link was always one of the worst brands, particularly when it comes to non-windows O.S. Sometimes even with windows, if I needed just the recent versions! But this is only my limited experience. And, anyway, VU+ images are not pure Linux: only linux-based O.S.
So it's not automatic that a device compatible to linux (which linux, also?) is compatible to every image for VU+.
bugima
Ok, so which modern high speed USB wireless adapter is actually compatible with BH 3.04 ? The list i have seen on this board i 3-4 years old and the adapters is likely not available in shop any longer.
waldemarp
After instalation of this image I have discover problem with connection between duo2 and vu+ playerHD- doesn't see the box. I have try manualy setup connetion but always get messege "connection fail". do you know how to get his works?
