Black Hole 3.0.4.C What is new ? - Update CrossEPG Providers - Update [opera-hbbtv] to fix youtubetv transparency issue INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash. This latest version of the Black Hole series has been updated and improved for maximum stability and performance. Please note that of all images Black Hole now has the best epg system: - Integrated OpenEpg - Rytec dedicated epg.dat - New system epg.dat outside. This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space. Community members can then download it from our servers. This feature provides other benefits such as: Increase download speed of EPG Download EPG from any channel Schedule the download of EPG decoder even during standby Users can customize the providers using Add / Remove function Main functions of the buttons on the remote OK button = Skin with simple information OK button x 2 = Extra Info Skin Blue button = Black Hole Blue Panel Blue button and then Red button = Black Hole Epg Panel Blue button and then Yellow button = System Monitor Panel Blue button long press = Extensions Yellow button = Audio menu Green button = Black Hole Green Panel Green button long press = Subservices Green button and then Red button = Fast Plugin Setup Green button x 2 = Fast Plugin Button Red short press= access HbbTv functions Button Red long press= Red Panel (Parallel Universes Teleportation) Addons Green button and then Yellow button takes you to:- Dedicated server for BlackHole addons Download and install additional packages from the Black Hole server Infobar / OSD Analog Clock Gui Channel orbital location Advanced Tuner Info: Sr Freq Pol Fec Signal SNR, BER Infobar picons Characteristics of BlackHole Panels Blue Panel Extra Settings Black Hole Speed Up Black Hole Cron Manager (Manage schedules) OSD Settings (OSD configuration) Devices Manager Usb Format Wizard Kernel Modules Manager(Kernel module operator) Inadyn Settings (Configure Inadyn) Swap File Settings (Configure File Swap) Hard Disk Settings (Configure Hard Drive) OpenVPN Panel ( OpenVPN Panel) Samba / CIFS Panel ( Samba Panel) NFS Server Panel ( NFS server Panel) Telnet Panel ( Telnet Panel) FTP Panel ( FTP Panel) UPnP Client Djmount UpnP Server Minidlna Pcsc Panel Tuner Server Network Browse & Mountpoints Info Panel 1 - Gui Setting (Gui configurations) 2 - Service Information (information system) 3 - About (info) Memory (Memory) Space (capacity) CPU (processor) Process (process) EPG Panel Global settings (global settings EPG) Setting Provider (ISP settings) Green Panel Fast Plugin Setup (Configure quick access to your favourite plugin) Fast Plugin (Access your favourite plugin) Addons (added) Addons Download Manager (Manager for package downloading) Online Feeds Settings update Online Black Hole image update Manual Install BH packges (Manual installation of Black Hole packages) Manual Install IPK packages (Manual installation of IPK packages) Addons Uninstall Panel (Uninstalled packages) Black Hole Statistics (See connections, top downloads and more) Characteristics of BlackHole Panels Red Panel BH Parallel Universe Teleportation BlackHole Avalon Chaos Ghost Credits Thanks to plnick for help obtaining missing Ultimo4K files. Thanks to Pedro_Newbie for Backup script. Thanks to the group of Beta Testers. Thanks to Rytec for providing us with the server with all epg.dat files. Thanks to MaxZ4 for Integrated EPG loader. Thanks to Skaman for Cross EPG Thanks to Lukkino (VDR-Italy) for the source code of OpenTV. Thanks to Reinh@rd for the file satellites.xml. Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code DISCLAIMER THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES. THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION. LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING. LICENSE (TERM OF USE) THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES. ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE. This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
Sall, how can I disable the darkness of the menu ?. When I start in the menu it was dark to be able to deactivate it?
