Black Hole 3.0.4 Vu+ Duo
Ev0
Admin
Black Hole 3.0.4​
What is new ?​
- Add Quad Picture in Picture support (Ultimo4K, Uno4K, Solo4K)
- Update CrossEPG to support new Rytec xz compression XMLTV listings
- Update CrossEPG to include latest Rytec Providers
- Update OpenWebif to fix Grab and WebTV
- Update Drivers (Ultimo4K, Uno4K, Solo4K, Duo2, SoloSE, Solo2, Zero)
- Fix FCC to work with usb tuners (Ultimo4K, Uno4K, Solo4K)
- Update Bluetooth Support (Ultimo4K, Uno4K, Solo4K)
- Update default skin to support Quad PiP
- Update Italian translations
1-png.31518
2-jpg.31506
3-jpg.31507
4-jpg.31510
5-png.31514
6-png.31513
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
An image can not cause interference problems, that can only be caused by something in your house (or neighbours house) interfering.
If it happens in 1 image and not in another, it is either just a coincidence (as you can not use both images on the same box at the same time, so the interference is not present when using the other image), or you are using slightly different frequency's to tune into that channel in the 2 images.
Either way, I would check your cabling, and if you have a dect phone, try moving it or turning it off, to see if the problem gets better (or worse).
Your neighbours dect phones can also cause problems as can old cabling.
please test it my Dear
i think this problem is in sattllite.xml file
i have not phone line in my new home
I wanted to trim the recording. In the menu I found Cutlist Editor. I marked what was to be cut out and ... - then it turned out that in the menu there is no command "Execute cut" that I have had in previous BH versions!
Had this command been hidden somewhere, or did the creators of the current Black Hole version forget about this feature?
My STB is VU+ Duo with BH 3.0.4.D image, but the problem is also on version 3.0.4.
Thank you guys for your precious work.
I moreover want to highlight a problem after updating the image of my VU Duo from 3.0.2 to 3.0.4, I can not download anymore TV programs by crossepg (rytec italy). I tried to update image, but it remains to 3.0.4 (It exists 3.0.4 D ?). I do not know what else to do and I did not found any direction from forum to fix problem. Are you working for this?
Regards
